F007 Internal thermal sensor fault in Schneider ATV310 drive
Cause : Internal thermal sensor detected fault comes when the drive temperature sensor is not operating correctly or the drive temperature sensor is in "short circuit" or "open".
"F007" fault in Schneider ATV310 drive indicate an internal thermal sensor fault. This means the internal temperature sensor might be damaged or malfunctioning.
  1. Check Drive Environment: Ensure the drive is installed in a well-ventilated area and not exposed to excessive heat sources.
  2. Verify Load Conditions: Check if the load on the drive is within its rated capacity. Excessive load can cause overheating.
