Cause : Process underload comes when the motor's current is consistently below a predefined threshold for a specific duration. This typically occurs when the motor is not properly connected to the drive or has become disconnected.
"F029" fault in Schneider ATV310 drive indicate "Process underload" fault. This means the motor current is consistently below a certain threshold for an extended period, indicating a potential issue with the application or motor load.
- Check Motor Connection: Verify that the motor is properly connected to the drive and receiving power.
- Inspect Motor Overload Protection: Check the motor's overload protection device for proper operation.
- Verify Motor Parameters: Confirm that the motor parameters (power, current, voltage, etc.) are correctly entered in the drive.
- Review Drive Configuration: Check the drive's current limit, motor protection, and other relevant parameters.
