1,170
Jul 19, 2024 5:00 am
Cause : Incorrect configuration comes when HMI block replaced by an HMI block configured on a drive with a different rating. This fault typically comes when the current configuration of customer parameters is inconsistent.
"F031" fault in Schneider ATV310 drive indicate "Incorrect configuration". This means there's a mismatch or inconsistency in the drive's parameter settings.Â
- Verify Motor Parameters: Ensure that the motor's specifications are correctly entered in the drive's configuration.
- Review Drive Parameters: Check for any inconsistencies or illogical settings within the drive's parameters.
- Restore Factory Defaults: As a last resort, consider restoring the drive to its factory default settings and reconfiguring it.
