FLA High speed reached warning in Schneider ATV610 drive
The message "FLA" High speed reached warning in Schneider ATV610 drive indicates a potential issue with the motor exceeding its recommended operating speed.
The FLA High speed reached warning on a Schneider ATV610 drive indicates that the motor has reached or exceeded a predefined high-speed limit set in the drive's parameters.
  1. This can be caused by various factors, including load conditions, improper parameter settings, or issues with the drive or motor.
  2. Verify the speed parameters set in the drive, including maximum speed limits and scaling.
  3. Ensure that command sources, such as PLCs or control systems, are correctly configured and not sending inappropriate speed commands.
