909
Jul 12, 2024 6:58 am
Learn the proper methods to reset faults on your Schneider Electric ATV610 drive, including self-resetting errors, non-resetting errors, and factory reset procedures. Ensure safety and prioritize addressing the root cause of the fault before resetting.
If you are facing any fault in Schneider ATV610 drive then follow these steps:
- Switching off the drive.
- Using the [Product restart] RP parameter.
- Using the digital input or the control bit assigned to [Prod Restart Assign] RPA.
- Using the [Auto Fault Reset] ATR– function.
- A digital input or control bit set to the [Fault reset] RST– function.
◦ For [Fault Reset Assign] RSF and [Extended Fault Reset] HRFC refer to [Fault reset] RST– Menu. - Pressing the STOP/RESET key on the Plain Text Display Terminal depending on the setting of [Stop Key Enable] PST.
