How to reset fault in Schneider ATV950 drive
If you want to "reset fault" in Schneider ATV950 drive then follow these steps:
Step 1: First Switching off the drive.
Step 2: Second using the "Product Restart" rP parameter. Enter this parameter then drive restart.
Step 3: Select the "Auto Fault Reset" Atr- function.
Step 4: A digital input or control bit set to the "Fault reset" "rSt- function".
Step 5: Pressing the "STOP/RESET" key on the Graphic Display Terminal if the active command channel is set to "Ref. Freq-Rmt.Term" LCC.
