INFD Internal error 13 fault in Schneider ATV950 drive
Cause : Differential current deviation comes when differential current deviation on parallel inverter bricks/power modules.
"INFD" Internal error 13 fault in Schneider drive indicate "Differential current deviation" issue. This means there is an imbalance in the current being drawn by each module.
  • Verify connections between inverter brick/power module outputs and device output terminals.
