735
Jul 24, 2024 7:14 am
Cause: Internal Error 22 comes when an error on the embedded Ethernet adapter has been detected. This could be due to various factors, including hardware issues, software glitches, or network-related problems.
"inFM" Internal Error 22 fault in Schneider ATV950 drive indicate "embedded Ethernet adapter error". This means a problem with the built-in Ethernet communication component within your device.Â
- Ensure the Ethernet cable is securely connected to both the device and the network.
- Check for and install any available updates for the network adapter driver.
- Try connecting to a different network to isolate the issue.
