PtHL Power low threshold reached warning in Schneider ATV950 drive
Cause: Power low threshold reached comes when the power consumption of a system or component has dropped below a predetermined minimum level. This warning comes when the system is not operating at its optimal capacity.
"PtHL" "Power Low Threshold" warning in a Schneider ATV950 drive indicates that the power consumption has fallen below a predefined low threshold. This can signal that the drive is drawing less power than expected, which could be caused by several issues, such as an underloaded system, a malfunctioning sensor, or configuration problems.
Here’s how to address the PtHL warning:
  1. Check Load Conditions:
    • Ensure that the load connected to the drive is within its expected operating range. A significant drop in load can lead to reduced power consumption. Verify that the load is operating as intended.
  2. Inspect Mechanical Components:
    • Examine the mechanical components such as the motor, bearings, belts, and gears. Look for any issues that could be causing the system to operate with less load than expected.
  3. Review Drive Configuration:
    • Verify the drive’s configuration settings, including power limits and thresholds. Ensure they are correctly set according to the application requirements and process conditions.
  4. Monitor Power Consumption:
    • Use the drive’s monitoring features to observe real-time power consumption. Compare it with the expected power draw to identify any discrepancies.
  5. Check Feedback Sensors:
    • Inspect any feedback sensors or devices that provide data on the load and power consumption. Ensure they are functioning correctly and providing accurate readings.
  6. Verify Power Supply:
    • Ensure that the incoming power supply is stable and within the specified range for the drive. Issues with the power supply can sometimes lead to abnormal power consumption readings.
  7. Inspect Control Elements:
    • Check any control elements (e.g., valves, actuators) involved in the process. Ensure they are operating correctly and not contributing to the low power reading.
