tLOF Drive Overload fault in Schneider ATV950 drive
Cause: Drive Overload comes when the drive is being subjected to a load exceeding its rated capacity. This can be caused by various factors, including mechanical issues, incorrect settings, or environmental conditions.
"tLOF" fault in Schneider ATV950 drive indicate " Drive Overload" condition. This means the drive is experiencing an overload condition, meaning that the current drawn by the motor is exceeding the drive’s rated capacity.
Here’s a structured approach to troubleshoot and resolve this issue:
1. Initial Checks:
  • Restart the Drive: Power off the drive, wait for a few minutes, and then power it back on. This can sometimes clear transient overload faults.
  • Review Fault Logs: Check the drive’s fault logs for any additional details or related fault codes that can provide more context.
2. Inspect Motor and Load:
  • Mechanical Inspection: Check the motor and connected load for any mechanical issues such as binding, jamming, or excessive friction.
  • Load Analysis: Ensure that the load connected to the motor is within the drive’s rated capacity. Overloading the load can cause the drive to enter an overload condition.
3. Check Drive Settings:
  • Overload Settings: Verify the drive’s overload settings and parameters. Ensure that the drive is configured with appropriate overload protection settings according to the motor’s specifications.
  • Motor Ratings: Confirm that the drive’s motor settings (e.g., rated current, rated power) match the specifications of the connected motor.
4. Verify Cooling and Ventilation:
  • Cooling Fans: Ensure that the drive’s cooling fans are functioning properly and that there is adequate ventilation around the drive.
  • Heat Dissipation: Check if the drive’s heat sink or cooling system is clean and free of dust or debris that could impede heat dissipation.
5. Monitor and Analyze Current:
  • Current Monitoring: Use the drive’s built-in monitoring tools or external measuring devices to check the current being drawn by the motor.
  • Peak Current: Determine if there are any instances of peak current exceeding the drive’s rated capacity and identify any patterns or conditions that lead to these peaks.
6. Inspect Power Supply:
  • Voltage Levels: Verify that the power supply voltage is within the specified range for the drive. Low or unstable voltage can cause the drive to draw excessive current.
  • Power Quality: Check the power quality to ensure there are no issues such as voltage sags, surges, or harmonics affecting the drive.
