Siemens Sinamics Power Module 250 Error Codes
"Siemens Sinamics Power Module 250 Error Codes" indicate an error occur in drive due to internal hardware problem or parameter issue. With the help of these error code you can easily identify and correct the issue in drive.
Fault codes Siemens Sinamics Power Module 250 and their solutions:
Fault Code Fault Name Cause
F30001 Overcurrent The power unit has detected an overcurrent condition in the drive.
F30002
DC link voltage overvoltage
The power unit has detected an overvoltage condition in the DC link.
F30003 DC link voltage undervoltage The power unit has detected an undervoltage condition in the DC link.
F30004 Overtemperature heat sink AC inverter The temperature of the power unit heat sink has exceeded the permissible limit value.
F30005 Overload I2t The power unit was overloaded (r0036 = 100 %).
F30015 Phase failure motor cable A phase failure in the motor feeder cable was detected.
F30021 Ground fault Power unit has detected a ground fault.
Click here for all fault, alarm & error codes
It's important to consult the specific user manual or documentation for your Sinamics Power Module 250 drive model to determine the exact meaning of error codes and troubleshooting steps. Additionally, contacting Sinamics Power Module 250 technical support or consulting with a qualified technician can help diagnose and resolve any issues with the drive.
