Siemens SIMOVERT Master Drive
764
Jun 28, 2024 5:29 am
Cause : SIMOLINK start alarm comes when start of the SIMOLINK ring is not functioning. This alarm signifies an issue with the communication link between a Masterdrive unit and a Slave drive unit within a SIMOLINK multi-drive configuration.
The A002 fault in siemens master drive indicates a SIMOLINK start alarm. This alarm signifies an issue with the communication link used for starting the drive through an external control system (e.g., PLC) via the SIMOLINK protocol.
- Check the fiber-optic cable ring for interruptions.
- Check whether there is an SLB without voltage in the ring.
- Check whether there is a faulty SLB in the ring.
