Siemens SIMOVERT Master Drive
439
Jun 27, 2024 8:58 am
Cause : EEPROM fault comes when a fault has occurred when storing the values in the EEPROM due to hardware issue in drive.
The Siemens Masterdrive fault code F041 indicates a problem related to the Control Board and Parameter Memory or EEPROM fault. This critical component stores the drive's operating parameters and settings.
- Replace CU (-A10), or replace the unit (Compact PLUS)
