Siemens SIMOVERT Master Drive
423
Jun 27, 2024 10:19 am
Cause : Parameter fault after factory setting/initialization comes when a fault has occurred in the initialization phase during the calculation of a parameter.
- The number of the inconsistent parameter is indicated in fault value r949.
- Correct this parameter (ALL indices) and switch voltage off and on again.
- Several parameters may be affected, i.e. repeat process.
