F116 fault in siemens master drive
The Siemens Masterdrive fault code F116 indicates an issue with the Technology Board (T300). This board is an optional add-on module for some Siemens Masterdrive models. It expands the drive's functionality by providing features like:
  • Advanced control algorithms: The T300 board might offer additional control capabilities beyond the standard functionality of the drive.
  • Increased encoder functionality: It could support more complex encoder types or provide additional encoder processing features.
  • Expanded communication options: In some cases, the T300 board might offer additional communication interfaces beyond the standard capabilities of the drive.
Here's a breakdown of the problem:
  • Cause: The drive encountered an error related to the T300 board. This can happen due to various reasons.
Possible Causes:
  • Missing or Incompatible Board: The T300 board might not be properly inserted, or it could be incompatible with your specific drive model.
  • Communication Interface Issue (if applicable): If the T300 board provides additional communication features, there could be an issue with the specific communication interface used.
  • Hardware Fault (More Likely for T300 Boards): Compared to other optional boards like CBs or TBs, T300 boards handle more complex control algorithms and might be more prone to internal hardware malfunctions.
