F01068 fault in siemens G120 Drive
Cause : CU: Data memory memory overflow - comes when the utilization for a data memory area is too large. If you're encountering an error indicating that the utilization for a data memory area is too large, it typically means that the amount of data being stored in that particular memory area exceeds its capacity.
- de-activate the function module.
- de-activate drive object.
- remove the drive object from the target topology.
