F07936 fault in siemens G120 Drive
Cause : load failure comes when the load monitoring has detected a load failure. A "load failure" can have various causes, but it generally indicates that the microcontroller is unable to properly load or execute the firmware or program.
- check the sensor.
- if necessary, de-activate the load monitoring (p2193).
See also: p2193 (Load monitoring configuration), p3232 (Load monitoring failure detection)
