F30021 fault in siemens G120 Drive
Cause : Ground fault comes when power unit has detected a ground fault due to ground fault in the power cables, winding fault or ground fault at the motor, CT defective.
- check the power cable connections.
- check the motor.
- check the CT.
- check the cables and contacts of the brake connection (a wire is possibly broken).
