F30664 fault in siemens G120 Drive
Cause : Error while booting comes when an error has occurred during booting. If you're encountering an error while booting your Siemens SINAMICS G120 drive, it indicates that the drive is experiencing difficulties initializing or starting up properly.
- carry out a POWER ON (power off/on).
- upgrade firmware to later version.
Here's a step-by-step approach to troubleshoot and address this issue:
  1. Power Cycle the Drive: Sometimes, a simple power cycle can resolve booting errors. Turn off the drive, wait for a few seconds, and then turn it back on. This can help reset the drive's internal components and clear any temporary glitches.
  2. Check Power Supply: Ensure that the drive is receiving a stable and adequate power supply. Verify that the power source is within the specified voltage and frequency range for the drive. Check for any fluctuations or interruptions in the power supply that could affect the booting process.
  3. Inspect Connections: Check all connections to and from the drive, including power cables, communication cables, and motor connections. Ensure that all connections are securely seated and properly tightened. Look for any signs of damage or wear that could affect the drive's operation.
