F30681 fault in siemens G120 Drive
Cause : Incorrect parameter value comes when he parameter cannot be parameterized with this value. If you're encountering an "incorrect parameter value" error message on your Siemens SINAMICS G120 drive, it typically means that one or more parameters in the drive's configuration have been set to values that are outside of the allowable range or are otherwise invalid.
Here's how you can address this issue:
  1. Review Parameter Settings: Access the parameter settings menu on the drive's interface or through the configuration software. Review the parameters that are displaying the error and check their values against the documentation provided by Siemens for the SINAMICS G120 drive.
  2. Correct Invalid Values: Identify any parameters that have been set to invalid or out-of-range values. Adjust these parameters to values that are within the specified range and appropriate for your application.
  3. Check for Typographical Errors: Ensure that there are no typographical errors or mistakes in parameter values. Sometimes, a simple error in inputting values can lead to the "incorrect parameter value" error message.
