F31940 fault in siemens G120 Drive
cause : Spindle sensor S1 voltage incorrect comes when the voltage of analog sensor S1 is outside the permissible range.
- Check the clamped tool.
- Check the tolerance and if required, adapt (p5040).
- Check the thresholds and if required, adapt (p5041).
- Check analog sensor S1 and connections.
