Siemens SINAMICS G120 Drive
419
Feb 16, 2024 10:48 am
cause : Run sequence value already assigned comes when an attempt was made to assign a run sequence value already assigned to a function block on this drive object to another additional function block on the same drive object. A run sequence value can only be precisely assigned to one function block on one drive object.
- Set another value that is still available on this drive object for the run sequence.
