Siemens SINAMICS G120 Drive
399
Feb 16, 2024 4:57 pm
cause : Analog sensor position value exceeds limit value comes when tThe position value has exceeded the permissible range of -0.5 ... +0.5.
1: Position value from the LVDT sensor.
2: Position value from the encoder characteristic
For fault value = 1: Check the LVDT ratio (p4678).
- check the reference signal connection at track B.
For fault value = 2: check the coefficients of the characteristic (p4663 ... p4666).
