Siemens SINAMICS G120 Drive
3,211
May 09, 2024 12:02 pm
Solution : If you want to factory reset siemens G120 drive parameter then use the following step :
1. First press "ESC" button then down button and goto the "SETUP" option.
2. Then press ok button and select "RESET" option.
3. After select RESET option then press ok button again.
4. After enter parameter display show BUSY. When setup is complete then restart drive.
now your drive reset to the factory default.
