Siemens SINAMICS G120 Drive
564
Jun 21, 2024 9:37 am
The F01039 error code in your Siemens Sinamics drive indicates writing to the parameter back-up file was unsuccessful. This file stores important configuration settings for your drive.
This fault indicate that writing to at least one parameter back-up file PSxxxyyy. in the non-volatile memory was unsuccessful due to there is not sufficient free memory space available or the non-volatile memory is defective and cannot be written to.
- Check the file attribute of the files (PSxxxyyy., CAxxxyyy., CCxxxyyy.) and, if required, change from "read only" to "writeable".
- Check the free memory space in the non-volatile memory. Approx. 80 kbyte of free memory space is required for every drive object in the system.
- Replace the memory card or Control Unit.
