A01224 alarm in siemens S120 Drive
Cause : Pulse frequency inconsistent comes when changing the minimum pulse frequency (p0113) inconsistency between the pulse frequencies was identified.
1: Value lower than minimum value.
2: Value higher than maximum value.
3: Resulting sampling time is not a multiple of 1.25 μs.
4: Value does not match clock-cycle synchronous PROFIBUS operation.
10: Special restriction of the drive object violated.
99: Inconsistency of cross drive objects detected.
116: Recommended clock cycle in r0116[0...1].
Set a valid pulse frequency. See also: p0113 (Minimum pulse frequency, selection)
