A01320 alarm in siemens S120 Drive
Cause : Drive object number does not exist in configuration comes when a drive object number is missing in parameter p0978.
Index of p0101 under which the missing drive object number can be determined.
Set p0009 to 1 and change p0978:
Rules:
- p0978 must include all of the drive object numbers (p0101).
- it is not permissible for a drive object number to be repeated.
- by entering a 0, the drive objects with PZD are separated from those without PZD.
- only 2 partial lists are permitted. After the second 0, all values must be 0.
- dummy drive object numbers (255) are only permitted in the first partial list.
