A01322 alarm in siemens S120 Drive
Cause : Drive object number present twice in configuration comes when drive object number is present more than once in p0978.
Alarm value (r2124, interpret decimal): Index of p0978 under which the involved drive object number is located.
Set parameter p0009 = 1 and change p0978:
Rules:
- p0978 must include all of the drive object numbers (p0101).
- it is not permissible for a drive object number to be repeated.
- by entering a 0, the drive objects with PZD are separated from those without PZD.
- only 2 partial lists are permitted. After the second 0, all values must be 0.
- dummy drive object numbers (255) are only permitted in the first partial list.
