Cause : Download interrupted comes when the project download was interrupted due to the user prematurely interrupted the project download or the communication cable was interrupted (e.g. cable breakage, cable withdrawn).
1: The user prematurely interrupted the project download.
2: The communication cable was interrupted (e.g. cable breakage, cable withdrawn).
3: The project download was prematurely ended by the commissioning software (e.g. STARTER, SCOUT). 100: Different versions between the firmware version and project files which were loaded by loading into the file system "Download from memory card".
- check the communication cable.
- download the project again.
- boot from previously saved files (power-down/power-up or p0976).
- when loading into the file system (download from memory card), use the matching version
Â
