F01658 fault in siemens S120 Drive
Cause : PROFIsafe telegram number differ comes when the PROFIsafe telegram number is set differently in p9611 and p60022. For p9611 not equal to 998, the following applies: The telegram number must be identically set in both parameters.
  • The following applies for p9611 = 998: As a result of the compatibility to firmware versions < 4.5, then only the values 0 and 30 are permitted in p60022.
  • Match the telegram number in both parameters so that they are the same (p9611, p60022).
