F05061 fault in siemens S120 Drive
Cause : Infeed VSM count comes when the number of active Voltage Sensing Modules (VSM) for the drive object infeed with chassis power units is not correct.
  • For A_Infeed, each active power unit must be assigned an active VSM also for a parallel circuit configuration.
  • For S_Infeed, the active drive object, must be assigned at least one active VSM.
  • Adapts the number of active Voltage Sensing Modules (VSM).
