A921 alarm in siemens V20 Drive
Cause : Analog output parameters not set properly comes when analog output parameters (P0777 and P0779) should not be set to identical values, since this would produce illogical results.
Check the following:
• Parameter settings for output identical
• Parameter settings for input identical
• Parameter settings for output do not correspond to analog output type Set P0777 and P0779 to different values.
