SINAMICS V20 Drive
1,563
Feb 22, 2024 5:02 am
Cause : Chip temperature rise exceeds critical levels comes when the chip temperature of the semiconductor has exceeded the permissible limit value.
- the permissible load duty cycle was not maintained.
- insufficient cooling, fan failure.
- overload.
- ambient temperature too high.
- pulse frequency too high.
Here's a guide on how to deal with an Chip temperature rise exceeds critical levels fault:
- adapt the load duty cycle.
- check whether the fan is running.
- check the fan elements.
- check whether the ambient temperature is in the permissible range.
- check the motor load.
- reduce the pulse frequency if this is higher than the rated pulse frequency
