F64 fault in siemens V20 Drive
Cause : Inverter attempted to do an automatic clone during startup comes when no Clone00.bin file in the correct directory /USER/SINAMICS/DATA.
If an automatic clone is required then follow these steps:
  • Insert the MMC/SD card with correct file and power-cycle. If no automatic clone is required:
  • Remove the card if not needed and power- cycle.
  • Reset P8458 = 0 and power-cycle.
Note: Fault can only be cleared by a power-cycle.
