Lvn fault in delta VFD-ED series drive
How can resolve problem Lvn fault in delta VFD-ED series drive ?
DC bus voltage at constant speed is less than the setting in Pr.06-00
corrective action
1. Check if the input voltage is normal.
2. Check for possible sudden load change.
Check wiring.
