oH3 fault in delta VFD-ED series drive
How can resolve problem oH3 fault in delta VFD-ED series drive ?
oH3 Motor Over Heat - Motor overheating The AC motor drive internal temperature exceeds the setting in Pr.06-27 (PTC level).
1. Make sure that the motor is not obstructed.
2. Ensure that the ambient temperature falls in the specified temperature range.
3. Change to a higher power motor.
Check wiring.
