WEG CFW08, CFW100 G2, CFW300 & CFW500 Drive
1,183
Apr 22, 2024 10:14 am
Cause : Overcurrent comes when the inverter turns off its output when the output current of the inverter flows more than the inverter rated current.
"E00" fault indicate that the output current exceeds the overcurrent detection level.
- When an overcurrent fault occurs, operation must be started after the cause is removed to avoid damage to IGBT inside the inverter.
- Increase the Accel/Decel time.
- Output short circuit or ground fault has occurred. Check output wiring.
- Mechanical brake of the motor is operating too fast. Check the mechanical brake.
