WEG Drives
1,443
Apr 22, 2024 10:51 am
Cause : Low voltage comes when the DC voltage is below rated voltage because insufficient torque or overheating of the motor can occur when the input voltage of the inverter drops.
- Line voltage is low.
- Check whether line voltage is below its rating.
- Load larger than line capacity is connected to line.
- Check the incoming AC line. Adjust the line capacity corresponding to the load.
- Faulty magnetic switch at the input side of the inverter.
- Change a magnetic switch.
