WEG Drives
1,084
Apr 22, 2024 10:58 am
Cause : Inverter overheat comes when the heat sink overheats due to a damaged cooling fan or the heat sink within the drive has reached a temperature above the specified threshold.
"E04" fault in weg drive indicate that the heat sink within the drive has reached a temperature above the specified threshold.
- Cooling system has faults.
- Check for alien substances clogged in the heat sink.
- An old cooling fan is not replaced with a new one.
- Replace the old cooling fan with a new one.
- Ambient temperature is too high.
