1,231
Mar 16, 2024 5:32 am
Cause : Control Board Connection Error comes when connection error between the control board and the drive or when drive fails to operate properly due to electrical signal interference.
- Turn off the power and check the connection between the control board and the drive.
- If the problem continues, replace the control board or the entire drive.
- Check the various options available to minimize the effects of noise.
- Counteract noise in the control circuit, main circuit, and ground wiring.
- Use only recommended cables or other shielded line. Ground the shield on the controller side or the drive input power side.
- Ensure that other equipment such as switches or relays do not cause noise. Use surge suppressors if required.
- Separate all communication wiring from drive power lines. Install an EMC noise filter to the drive power supply input.
