392
Mar 16, 2024 5:37 am
Cause : FLASH Memory Fault comes when problem with the ROM (FLASH memory). If you're encountering a "Flash Memory Fault" on a Yaskawa A1000 drive, it suggests an issue with the flash memory component of the drive's control system. Flash memory is used to store firmware, configuration settings, and other critical data.
- Hardware is damaged: Replace the drive.
