dEv alarm code in yaskawa A1000 drive
Cause : Speed Deviation (when using a PG option card and AOLV/PM without PG) comes when the deviation between the speed reference and speed feedback is greater than the setting in F1-10 for longer than the time in F1-11.
  1. Load is too heavy. Reduce the load.
  2. Acceleration and deceleration times are set too short. Increase the acceleration and deceleration times (C1-01 through C1-08).
  3. The load is locked up. Check the machine.
  4. Parameter settings are inappropriate. Check the settings of parameters F1-10 and F1-11
  5. Incorrect speed feedback scaling when using terminal RP as speed feedback input in V/f Control.
    • Set H6-02 to value of the speed feedback signal frequency when the motor runs at the maximum speed.
    • Adjust the speed feedback signal using parameters H6-03 through H6-05.
    • Make sure the speed feedback signal frequency does not exceed the maximum input frequency of terminal RP.
  6. The motor brake engaged. Ensure the brake releases properly.
