dv1 fault code in yaskawa U1000 drive
Cause : Z Pulse Fault comes when the motor turned one full rotation without the Z Pulse being detected. PG encoder is disconnected, improperly wired, or the PG option card or PG encoder are damaged.
1. Make sure the PG encoder is properly connected and all shielded lines are properly grounded.
2. If the problem continues after cycling power, replace the PG option card or the PG encoder.
