E5 fault code in yaskawa U1000 drive
Cause : MECHATROLINK Watchdog Timer Error comes when the watchdog timed out due to data has not been received from the PLC.
  • Execute DISCONNECT or ALM_CLR, then issue a CONNECT command or SYNC_SET command and proceed to phase 3. Refer to the SI-T3 Option Technical Manual for more details on troubleshooting.
