EF0 fault code in yaskawa A1000 drive
Cause : Option Card External Fault comes when an external fault condition is present. An external fault was received from the PLC and F6-03 is set to a value other than 3.
• Remove the cause of the external fault.
• Remove the external fault input from the PLC.
Problem with the PLC program Check the PLC program and correct problems.
