296
Mar 21, 2024 5:20 pm
Cause : External Fault (input terminal S1) comes when external fault at multi-function input terminal S1. When an external device tripped an alarm function or wiring is incorrect or multi-function contact input setting is incorrect.
- Remove the cause of the external fault and reset the fault.
- Properly connect the signal lines to the terminals assigned for external fault detection.
- Reconnect the signal line.
- Change the terminal settings.
