294
Mar 22, 2024 9:36 am
Cause : Rated Slip Error comes when motor data entered during Auto-Tuning was incorrect or results from Auto Tuning are outside the parameter setting range or the tuning process took too long.
- Make sure the data entered to the T1 parameters match the information written on the motor nameplate.
- Restart Auto-Tuning and enter the correct information.
- Check and correct faulty motor wiring.
- Perform Rotational Auto-Tuning.
- The load was too high during Rotational Auto-tuning.
- Disconnect the motor from machine and restart Auto-Tuning. If motor and load cannot be uncoupled make sure the load is lower than 30%.
- If a mechanical brake is installed, make sure it is fully lifted during tuning.
