HCA alarm code in yaskawa U1000 drive
Cause : Current Alarm comes when rive current exceeded overcurrent warning level (150% of the rated current) or load is too heavy.
  1. Reduce the load for applications with repetitive operations (i.e., stops and starts), or use a larger drive. Acceleration and deceleration times are too short.
    • Calculate the torque required during acceleration and for the moment of inertia.
    • If the torque level is not right for the load, take the following steps:
    • Increase the acceleration and deceleration times (C1-01 through C1-08).
    • Use a larger drive.
  2. A special-purpose motor is being used, or the drive is attempting to run a motor greater than the rated output current.
  3. Check the motor capacity.
  4. Use a motor appropriate for the drive. Ensure the motor is within the rated output current range.
  5. The current level increased due to Speed Search after a momentary power loss or while attempting to perform a fault restart.
  6. The alarm will only appear briefly. There is no need to take action to prevent the alarm from occurring in such instances.
