357
Mar 16, 2024 8:45 am
Cause : Node Setup Error comes when a terminal assigned to the node setup function closed during run due to overcurrent occurred during Overexcitation Deceleration.
- The node setup terminal closed during run. Reduce the overexcitation deceleration gain (n3–13).
- A Run command was issued while the node setup function was active. Stop the drive when using the node setup function.
