oFA01 fault code in yaskawa U1000 drive
Cause : Option Card Fault at Option Port CN5-A comes when the option card connection to port CN5-A is faulty or option not properly connected.
• Turn off the power and reconnect the option card.
• Check if the option card is properly plugged into the option port. Make sure the card is fixed properly.
• If the option is not a communication option card, try to use the card in a different option port. If the option card works properly in a different option port, CN5-A is damaged, and the drive requires replacement. If the error persists (oFb01 or oFC01 occur), replace the option card.
